m89 Posted February 10, 2011 Share Posted February 10, 2011 Hi guys, I am currently working on a FX project at university and have hit a wall when it comes to animating the crack. The method i decided to was to pre- fracture the object (currently a grid for tests) using Voronoi shatter and then isolating each piece and emitting a particle from each piece. Then attaching the geometry piece to the particle and using a force to manipulate the movement of the particles, which affect the fractured geometry. The main problem i have found is in the connectivity of the piece as only some of the primitives are affected by the particles so there is a wierd affect going on here. In a newer version i changed it to points, but later on there are different issues with moving the translated pieces back to their grid for the final effect. I have attached a test of it, the particles and everything seem to working apart from the individual pieces being moved. Any help would be really appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 10, 2011 Share Posted February 10, 2011 To animate a crack up a wall use the l-system. Use a Project SOP to project the points onto a Grid, then animate the generation of the l-system to make it grow. The l-system comes with a prefined cracked pattern (under the gear menu). You can then emit particles from the last points of the l-system to project bits out of the tip of the cracks are it grows. You might need to exclude and cookie a box using the l-system to create a solid wall that is breaking up. p.s. You didn't have an attached. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 10, 2011 Share Posted February 10, 2011 Here's a crack running up a wall. It's a thick but you can easily make it thinner. cracking-wall.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Sifis Posted February 11, 2011 Share Posted February 11, 2011 Oh that's cool hopbin9, It works perfectly for me. Actually, I've not ever think to use L-Systems for this. Thanks! Quote Link to comment Share on other sites More sharing options...
m89 Posted February 11, 2011 Author Share Posted February 11, 2011 Hey hopbin9, Thanks so much for the help, i will definately give it a shot and let you know how it goes. Sorry about the attached file, i thought it had uploaded. thanks m89 Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted March 3, 2011 Share Posted March 3, 2011 Cracking with particles emitting from the last point in the l-system. cracking-wall-particles.hipnc Quote Link to comment Share on other sites More sharing options...
Omy Posted March 5, 2011 Share Posted March 5, 2011 Cracking with particles emitting from the last point in the l-system. would a boolean operation can be responsible to produce cracks in different surfaces from a simple sphere to a modelled obj Quote Link to comment Share on other sites More sharing options...
m89 Posted March 15, 2011 Author Share Posted March 15, 2011 Cracking with particles emitting from the last point in the l-system. Hi thats awesome! that was my next task. I was wondering with using the L-system is there a way of keeping the animation, but changing the shape of the crack? Every time I change the the L-system shape the animated crack stops. Also I have looked at another way of cracking, this is the version someone sent me, which i have been trying to tweak, but when adding a new crack.bgeo the lattice and spring doesn't work. The lattice says the geometry is unmatched. Im not sure what i am missing. Would be great if you could take a look. Thanks m89 cracks.zip 1 Quote Link to comment Share on other sites More sharing options...
nMolson Posted June 18, 2012 Share Posted June 18, 2012 Hi thats awesome! that was my next task. I was wondering with using the L-system is there a way of keeping the animation, but changing the shape of the crack? Every time I change the the L-system shape the animated crack stops. Also I have looked at another way of cracking, this is the version someone sent me, which i have been trying to tweak, but when adding a new crack.bgeo the lattice and spring doesn't work. The lattice says the geometry is unmatched. Im not sure what i am missing. Would be great if you could take a look. Thanks m89 did you ever find a solution to this? i would like to use a custom curve to guide the crack with this system but cant get it to work Quote Link to comment Share on other sites More sharing options...
