pyro shader pulsing
Hey,
I am having problems with noise pulsing on the pyro shader ...
I am using the dual rest position - set to 20 on the pyrosolver and fireball_pyro shader.
The noise is really pulsing quite badly ... am I missing something?
I am using H11.0.653
Thanks!
Stephen
Try to raise the rest rate.
The 2 rest fields are "crossfading", so if your interval is to short it might get noticeble.
Mario explains more here
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16117&start=0&postdays=0&postorder=asc&highlight=dual+rest
Hey,
Thanks for the help... extending the rest reset position did indeed help a lot! (it did soften the features a lot too - which I guess is due to the long mix between rest positions). I am just surprised this crossfading happens globally... would be great if there was a way the rest pos somehow tested how far it was streched locally and then reseeded the rest position 2 when and where needed. I guess this is easy for me to say but I have no idea of the practicalities of implementing it!
cheers!
Stephen
Could this be related to Journal Entry:
Monday, Febuary 7, 2011
Houdini 11.0.650: The Pyro Shader will now properly respect a 50 frame rest reset. Previously, the VEX code had a default of 20, not matching the UI default. This caused the shader to actually use a reset rate of 20 when the UI was set to 50.
This pyro shader behaviour has been discussed before and I have experienced it myself.
Edited by Macha
