DaJuice Posted September 5, 2003 Share Posted September 5, 2003 Hi again, back with another question. I have a popnet that's instancing metaballs for geometry. Instead of the particles popping (bad pun) out of existence I want them to shrink to nothing at the end of their life. I'm using a Property POP to mess with the pscale attribute, and I'm trying to find an expression that will do what i described. What do I need to do so Houdini knows I want the expression to work on each particle from the time it spawns until the time it dies? Anyone have an idea how I should reference that info? Thanks. Quote Link to comment Share on other sites More sharing options...
concept4 Posted September 5, 2003 Share Posted September 5, 2003 Try placing two property ops and initialize the scale in the first one with the correct number you need and then in the second property op you could reduce the scale of each particle over its life with this expression: $PSCALE - ($PSCALE*$LIFE) If you want to start the scaling at a certain age and not from the start you could replace the $LIFE in the expression with a smooth function. This will start to scale the particles down when they've reached 70% of their lifespan: $PSCALE - ($PSCALE*smooth($AGE, .7,$LIFESPAN)) Hope this is what you were looking for --Ronnie smooth_interp.zip 1 Quote Link to comment Share on other sites More sharing options...
DaJuice Posted September 5, 2003 Author Share Posted September 5, 2003 You da man! That worked like a charm, thanks a lot! I'll try and post an animation once it's all done. Quote Link to comment Share on other sites More sharing options...
