pyro Auto resize and upres problem
Ungoliant
Hello people
i have this problem, im trying with the autoresize technique with sop solver, but i have a problem when i try to create the upres sim, the upres node cant find the required fields for the process,
I attached the file so that you can see
hopefully you can help me because I needs to use the AutoResize with upres
thanks
autoresize_and_upres.hipFetching info...
  On 3/12/2011 at 8:13 AM, Ungoliant said:
Hello people
thanks
1. Your Gas resize looks at pyro1 for size and center while your object accually is called just pyro.
2. Have you run the low res sim and saved it to disk? The uprespyro node says that it cant find the lowres fields. By default(using shelf) it looks at the path set in
obj/lowrespyro/pyrofields ->Geometry file.
I think P.Quint has a tutorial on the upres process on hes Vimeo site.
edit...
You would need to build a separate resize tree for your upres.
Edited by mawi
  • 11 months later...
edit...
Yes a separate sop-solver to resize the upres(density) works fine.
btw.. Hello Martin! You have misspelled stockholm in your profile ;)
/Stefan L
Edited by kwejk
