kumpa Posted March 14, 2011 Share Posted March 14, 2011 What would be best way to do that in houdini ? Quote Link to comment Share on other sites More sharing options...
Macha Posted March 14, 2011 Share Posted March 14, 2011 (edited) Isn't that just parenting? Or a point/centroid expression, copy-pasting a parameter, or do I miss something blindingly obvious here? Edited March 14, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
sanostol Posted March 14, 2011 Share Posted March 14, 2011 Isn't that just parenting? Or a point/centroid expression, copy-pasting a parameter, or do I miss something blindingly obvious here? no, parenting means the childs follow a parent, but in this case it works in both directions Quote Link to comment Share on other sites More sharing options...
old school Posted March 14, 2011 Share Posted March 14, 2011 The Maya constraint only evaluates once the cursor is lifted off one of the objects looking at this video. No way for me to confirm this but if this is the case, fail. This is definitely a feedback type constraint. I don't know how an animator would make sense keying in to this but that is a whole other matter. Generally you build bi-directional constraints between two end points on a spine and use a kinematics solver to solve the in-between joints. This is going to be a custom script/asset solution as is the Maya solution. There seems to be quite a few solutions in Maya for bi-directional constraints each with varying levels of success and compromises and most have to do with Spine rigs, not two objects countering each other. You could create a custom object asset and try using callback scripts to do this. Just pick up the driver_driven object custom tx ty and tz channels then add the difference between the start value and the current value. This should work when you manipulate the parameters but these sort of feed-back callback scripts do NOT currently work with Handles in the viewport. You could use DOPs in timeless mode to solve the constraint relationship. DOPs does solve on viewport interactions so it should be straightforward to build this with a Script Solver. All the solver is doing is picking up starting positions, recording the movement of the first object and adding it to the second object, whichever one is being moved. Should be very fast. Quote Link to comment Share on other sites More sharing options...
rdg Posted March 14, 2011 Share Posted March 14, 2011 The Maya constraint only evaluates once the cursor is lifted off one of the objects looking at this video. The interface shown in the video suggests they're using the scriptJob MEL command to rewire the constraints on the fly. Quote Link to comment Share on other sites More sharing options...
graham Posted March 14, 2011 Share Posted March 14, 2011 (edited) Here is a quick example of doing this for two objects using HOM and node event callbacks. Since you can't edit callback scripts of base parameters on objects you can use the node events to get it done. Using a dummy variable in hou.session to prevent recursion it seems to work pretty well. The only down side in certain situations is that it only detects changes on the whole tuple, not individual components. If you wanted to have say only 'tx' constrained it wouldn't work. The code is generalized to support other parms as well, not just 't'. import hou n1 = hou.node('/obj/sphere_object1') n2 = hou.node('/obj/box_object1') event_types = (hou.nodeEventType.ParmTupleChanged,) hou.session.busy = False def onParmChange(**kwargs): if hou.session.busy: return parm_tuple = kwargs['parm_tuple'] if parm_tuple is not None: tuple_name = parm_tuple.name() if tuple_name in ('t',): hou.session.busy = True node = parm_tuple.node() if node == n1: n2.parmTuple(tuple_name).set(parm_tuple.eval()) if node == n2: n1.parmTuple(tuple_name).set(parm_tuple.eval()) hou.session.busy = False n1.addEventCallback(event_types, onParmChange) n2.addEventCallback(event_types, onParmChange) Edited March 14, 2011 by graham Quote Link to comment Share on other sites More sharing options...
kumpa Posted March 15, 2011 Author Share Posted March 15, 2011 (edited) Thank you everyone for your answers, what I am aiming for is to mimic MotionBuilder default character rig where you can create any number of "auxilary affectors", grab any of them and rotate whole limb around it and the rest would follow. Edited March 15, 2011 by kumpa Quote Link to comment Share on other sites More sharing options...
Dennis Posted March 15, 2011 Share Posted March 15, 2011 I don't know in which version of Houdini this actually happened, but for some time now simple channel references are bi-directional in Houdini. Quote Link to comment Share on other sites More sharing options...
sanostol Posted March 15, 2011 Share Posted March 15, 2011 (edited) I don't know in which version of Houdini this actually happened, but for some time now simple channel references are bi-directional in Houdini. wtf, weird it works even with expressions, like: ch("../null1/ty")+sin($FF*3)*3 Edited March 15, 2011 by sanostol Quote Link to comment Share on other sites More sharing options...
