jfhtx Posted March 17, 2011 Share Posted March 17, 2011 I think that it is time for Side effect to make a new version of their gwavefront utility which Converts .obj files to/from Houdini format. There is now enough programs in the market which are dealing with wavefront .obj and material .mtl. Please join me to ask Side Effects to provide and .obj utility with .mtl IN/OUT. Thank you. I can see on Google that cg artists where already requesting this since 2008. we are now in 2011 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 17, 2011 Share Posted March 17, 2011 Not trying to shoot down the request, just wondering what actually uses the MTL file? I've never once used it for anything. OBJ/MTL is archaic and ASCII (which means slow and inefficient). I'd much rather see the development time spent on something else unless there's a significant use for the MTL file. Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted March 17, 2011 Share Posted March 17, 2011 You need the MTL for Photoshop-Import - here is a fix: Houdini and Photoshop CS 3 Extended Quote Link to comment Share on other sites More sharing options...
jfhtx Posted March 18, 2011 Author Share Posted March 18, 2011 You need the MTL for Photoshop-Import - here is a fix: Houdini and Photoshop CS 3 Extended Ya thank you for the tip but I know what to do if I have to add with my notepad 1/2 textures and 2/3 materials.I'm talking about a version of gwavefront which can deal obj/mtl with a bigger number of materials and textures.As I said into the SideFx forum,I can't afford to pay a full license to get access to other importer/exporter.(I have apprentice HD).For the artist(Apprentice is for those people)it will definitively open new doors. Quote Link to comment Share on other sites More sharing options...
jfhtx Posted March 18, 2011 Author Share Posted March 18, 2011 Not trying to shoot down the request, just wondering what actually uses the MTL file? I've never once used it for anything. OBJ/MTL is archaic and ASCII (which means slow and inefficient). I'd much rather see the development time spent on something else unless there's a significant use for the MTL file. You can send this to autodesk because they are now owning Maya and Maya since the beginning is all about obj. I remember in 1992 that on SGI alias wavefront was very happy with that file format. Quote Link to comment Share on other sites More sharing options...
ben Posted March 18, 2011 Share Posted March 18, 2011 (edited) Use Autodesk FBX converter to convert your obj/mtl to fbx You can batch as many files as you want. In houdini : file -> import fbx. You get your object with material and texture. Et voilà ! Edited March 18, 2011 by ben Quote Link to comment Share on other sites More sharing options...
jfhtx Posted March 18, 2011 Author Share Posted March 18, 2011 Use Autodesk FBX converter to convert your obj/mtl to fbx You can batch as many files as you want. In houdini : file -> import fbx. You get your object with material and texture. Et voilà ! Thank you Ben, Since a long time I'm trying to EXPORT from HOUDINI an .OBJ and MTL without success. Here is the dilemma: there is after Blast more then 900 primitive group with different colors. I'm puting a partition and a blast so when I export the file to obj,I can retrieve in other software the different group.(at least this is a step!!).But after assigning to all those groups a material is really a nightmare. I don't understand that policy to offer to artists a beautiful piece of software and at the same time to cut some fingers(like export of fbx,collada and that OBJ/MTL). Quote Link to comment Share on other sites More sharing options...
ben Posted March 18, 2011 Share Posted March 18, 2011 Did you consider writing a custom python node to export a mtl ? I think this would be fairly easy... Another thought : If you only need to get colors maybe you can go straight with vertex color and .ply format. you will easily find max or maya .ply importer plugin But I agree with you I would love to have a fbx export with the HD verion of houdini (even if I understand why it's not available). Quote Link to comment Share on other sites More sharing options...
jfhtx Posted March 18, 2011 Author Share Posted March 18, 2011 Did you consider writing a custom python node to export a mtl ? I think this would be fairly easy... Another thought : If you only need to get colors maybe you can go straight with vertex color and .ply format. you will easily find max or maya .ply importer plugin But I agree with you I would love to have a fbx export with the HD verion of houdini (even if I understand why it's not available). Thank you, concerning writing a custom python is out of my mind.But I will try the .ply format. Quote Link to comment Share on other sites More sharing options...
jfhtx Posted March 19, 2011 Author Share Posted March 19, 2011 (edited) Thank you, concerning writing a custom python is out of my mind.But I will try the .ply format. I tried the .ply format and it does export color info,bur now I have to find one translator .ply-->.obj/mtl Edited March 19, 2011 by jfhtx Quote Link to comment Share on other sites More sharing options...
Farsheed Ashouri Posted May 2, 2013 Share Posted May 2, 2013 I wrote a little script for this problem today. Guess it might be useful for community. So I share it. It adds materials as groups to .obj file. Usage is simple. python hobj.py <path to your obj file>[/CODE]hobj.py.tar.gz Quote Link to comment Share on other sites More sharing options...
Farsheed Ashouri Posted May 2, 2013 Share Posted May 2, 2013 (edited) A little bug fixed. hobj.py.0.1.3.tar.gz Edited May 2, 2013 by Farsheed Ashouri Quote Link to comment Share on other sites More sharing options...
Farsheed Ashouri Posted May 2, 2013 Share Posted May 2, 2013 Some output cleanup. This is final version (I hope) Quote Link to comment Share on other sites More sharing options...
