quarel Posted April 10, 2011 Share Posted April 10, 2011 hi there guys! little head-worm for me. I made stairs- plates. But very long time-not-procedural way. (see attachment) I'm surely that it could go any more effective way. Please can someone try to show me how? What if I would like to go from Square plate to triangon plate. Or whateaver two shapes blend between themselves? stairs.hipnc Quote Link to comment Share on other sites More sharing options...
Macha Posted April 10, 2011 Share Posted April 10, 2011 (edited) Try a copy sop! For the shapeblend, try this: stairs.hipnc Edited April 10, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted April 10, 2011 Share Posted April 10, 2011 (edited) Here Dalibor, try this as well. NURBS skinning. stairs2.hipnc Edited April 10, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
quarel Posted April 11, 2011 Author Share Posted April 11, 2011 hey macha, the stairs 2 is much better. Something that I was looking for. But not completely. This plates are a little curved or not horizontal straight. Of course I tried copy sop:) but it wasnt exactly what I needed. First and second plate was different shapes. Also I'm going to study "shape deformation" thread. Looks interesting. Exactly as there: your last post : how to make plates from converted COLUMNS in this case? the best procedural way:) I posted it here a little modified hip file and prtscreen. Thanx a lot ! convertedPlates.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted April 11, 2011 Share Posted April 11, 2011 first of all to make blendshapes SOP work correctly you should have the same number of points on each input, which is not the case in your file this is easy with resample SOP but to make plates you need all your curves to be closed, now you have open circle to keep sharp edges on the X shape I resampled it by edge then just used final point count to resample circle look at the file if it's what you want convertedPlates_fix.hipnc Quote Link to comment Share on other sites More sharing options...
quarel Posted April 11, 2011 Author Share Posted April 11, 2011 first of all to make blendshapes SOP work correctly you should have the same number of points on each input, which is not the case in your file this is easy with resample SOP but to make plates you need all your curves to be closed, now you have open circle to keep sharp edges on the X shape I resampled it by edge then just used final point count to resample circle look at the file if it's what you want hey tomáš, that is maximally cool! also for fabrication. Thank you! ďakujem! Quote Link to comment Share on other sites More sharing options...
