delete by expression
quarel
and here is an example if you want to delete pieces which are made only from single metaball(may be deformed but not connected to other)
with a little note inside
please look at this file even if above example was what you need since this file contains some optimizations to your setup
je to vsetko po anglicky, ale ak by si mal s niecim problem mozeme pokecat aj sukromne, zatial sa maj
grid_meta_delete_alone.hipnc
wow great Tomáš! both solutions are proffesional!
not connected to what?
not connected at least with one other metaball.
this optimalizations are really great! I have more huge area converted to metaballs so this surely can help me!
thankyou very much.
viac napisem sukromne.
Edited by quarel
hi, anim, it's good method. but I found your method didn't work in the houdini 10.
we can use Intersect VOP to get the right intersected primitives, but the value of "class" isn't correct when I use Primitive Attribute VOP to get the value "class".
what's wrong?
thanks.
grid_meta_delete_alone_10beta.hip
sorry sparkChan, I don't have H10 installed at the moment
but if there is problem that Primitive Attribute VOP is not importing Primitive attribute "class" then try to promote "class" to points on metaball geometry just before vop sop
then Primitive Attribute VOP should get that attribute by weighting all points of intersected primitive and since all will have the same value you should get correct integer number
EDIT: and in VOP SOP be sure to include something like in my file for case where no intersection was found, I am assigning -1 as a class to those particles in order they not interfere with others
in your case they are getting 0 so if your metaball with class 0 is alone and at least one other cannot resolve intersection and returns also 0 then your alone metaball will not get deleted
but if you make sure that all points find intersection then its ok
Edited by anim
