Handling image sequences
I'm creating a wall of TVs and each TV will have a different image displayed on. So I want to change the image sequence being shown based upon a random value.
My problem is that each sequence is a different number of files, and I need the video to loop. I can do something like this
$HIP/images/video`ch('video')`/image_`padzero(3,wrap($F,1,500))`.png
Where 500 is the length of the video sequence.
Is there an hscript expression that will tell me how long the sequence is?
if you read your sequence into File COP and then using expression like:
seqlength()
or in Python
sequenceFrameLength()
will tell you that
so to be more effective, create little python script that will loop all your sequences, get their lengths by loading them to a single File COP one by one and outputs lengths to file or to some node as custom data or somewhere
or if you do it in Python SOP, then you can store that data directly to corresponding points of your TV grid
Just make sure it's not realtime, but as a callback script for some button
Edited by anim
Haven't testing it, just a quick sketch, but something like this should work in text filed
import os
HIP = hou.expandString("$HIP")
videoFolder = "video_%d" % 1 # random number here
pathToSeq = "%s/images/%s" % (HIP,videoFolder) # fullPath to video folder
seqLength = len(os.listdir(pathToSeq))
F = int(hou.hmath.wrap(hou.frame(),1,seqLength)) #frame wraping
F = str(F).zfill(4) #padding
fileName = "image_%s.png" % F
fullPath = "%s/%s" % (pathToSeq,fileName)
return fullPath
  • Thanks 1
import os
return fullPath
To clean things up a bit, that could be put into the session module as a function. Then call the function with hou.session.defNameHere(argsHere). The session module gets saved into the scene file.
http://www.sidefx.com/docs/houdini11.0/hom/session
If a Python expression is going to take more than a single line then I will put it into the session module (or an external module) to keep things as organized as possible. If you find you need it later in a another scene then the session can be exported as a stand alone Python script and then imported into another scene.
