Python Console Reflection
Do you want to see what Houdini is doing for scripting reference or for performance monitoring? If you just want to see what is "cooking" then use the performance monitor from the Windows menu. Check the box to enable monitoring otherwise it won't record anything. If you want scripting reference then check out the help documents.
http://www.sidefx.com/docs/houdini11.0/hom/
http://www.sidefx.com/docs/houdini11.0/hom/hou/
Thanks. Its more for reference. Seeing the command reflection of actions you perform in the UI in Maya is an easy way for artists to prototype scripts or create repro cases for debugging. I was just wondering if there was something similar in Houdini. It seems there is essentially a command for every action performed in the UI, but those commands are not called by the application when the actions are actually performed.
Cheers
Cheers
Maya does most things as a process in the interface, but Houdini does things differently with the nodes. So even if you could see what it does in a console, it wouldn't be meaningful like it is in Maya. Instead you can figure out some of what Houdini does and implement it again in Python with the asCode() method for some objects. It will return the Python code necessary to recreate the object. Not all objects have this method, but a lot do.
