FIELD Posted May 10, 2011 Share Posted May 10, 2011 Hey Peeps, Im new to Houdini and currently trying to get into its dynamics system. Ive setup a simple scene that looks like a 2D arcade game (super mario) - multiple elements fall down and collide with the 'level' geometry - that all works fine. Now I'd simply like to constrain the falling elements to always stay on a 2D plane (z=0) but cant figure out how to setup the DOP nodes. I guess one would use a Constraint + Hard Connection Relationship + Anchor Object Space Position + Anchor World Space Position nodes - correct? If so how do you set them up so the constraint works with all elements of the fractured object? Any tips / help please? Cheers Marcus Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 10, 2011 Share Posted May 10, 2011 have a look at the apply relationship dop Quote Link to comment Share on other sites More sharing options...
anim Posted May 10, 2011 Share Posted May 10, 2011 what about just setting position Z and velocity Z to 0 each timestep? maybe at the end of the dop tree to override all objects? Quote Link to comment Share on other sites More sharing options...
FIELD Posted May 10, 2011 Author Share Posted May 10, 2011 what about just setting position Z and velocity Z to 0 each timestep? maybe at the end of the dop tree to override all objects? @Tomas that's exactly what Im trying to do - is there a simple way to do this? I tried an apply data + position node after gravity but that didnt seem to affect anything. @Kuba the relationship dop is a bit overwhelming, but it seems that once i have the plane constraint working for a single object that behaviour could be copied onto all other objects with it? Quote Link to comment Share on other sites More sharing options...
anim Posted May 10, 2011 Share Posted May 10, 2011 here it is just setting tz to 0 DOPs_RBD_2D.hipnc Quote Link to comment Share on other sites More sharing options...
FIELD Posted May 15, 2011 Author Share Posted May 15, 2011 here it is just setting tz to 0 Oh wow - thanks Tomas! Your example works fine, but when i try to apply it to my fractured rigid body object only one of the elements is constrained to the plane. Will try and experiment a bit more, but at least that points me in the right direction ... Quote Link to comment Share on other sites More sharing options...
