Prevent Houdini From showing hidden folders
RickW
When I choose File->New or File->Open and browse to my home directory, Houdini lists all folders in there, hidden or not. I have a bunch of folders that are named like .fluxbox, .xmms, .gimp-1.3, etc.
If I type ls in a shell, I can not see this folders. If I open up nautilus or another GUI File Manager I can not see these unless I enable "show hidden files"
In Houdini, I checked the Main Preferences and there's an option to "show hidden files". The default is unchecked but I don't think it applies to the file browser.
Any thoughts?
Using Houdini 6.1.x, Linux
Thanks,
/Rick
Hey Rick,
I don't think there is a way to change that.
You can setenv foo '$HOME/hip' in your .tcshrc, .bashrc or .login file & typing $foo into the path parameter will bring you directly to the directory.
Or better yet, typing $foo/myhip.hip into the file parameter will open or save the file immediately.
Cheers!
steven
Hi Steve,
I didn't know Houdini will read the environment variables that I set in my .rc file. Do you know if there's a way to get my list of varibles to show up in the "Jump" dropdown menu under the file save/open dialog? I'd like to set Job specific paths like:
JOB1
JOB2
JOB3
Currently I see HOME, TMP, JOB, etc in that menu.
I tried editing the houdini_setup file as root but my variables are not in that dropdown menu.
Thanks,
/Rick
