bug: no mouse click input anymore
hi
from time to time I have a strange bug, it happens when switching networks with mouse with the jumpback/jumpforward buttons. houdini does not see any mouse and keyboard inputs anymore beside moving the mouse
there is no way to save anymore, only way to do is to click on the close button, then houdini asks if You want to save or discard, in case of save houdini asks for a filepath, and You can not enter anything and that's it
if it has a proper filename you can save.
because of this and other things i tend to use keyboard shortcuts for switching networks, but from time to time it still happens
i'm just curious if other users have encountered similar behavior. i guess it is one of these hard to reproduce bugs, cause it is not nodedependent
Martin
I don't have it with switching networks but this behavior sometimes occurs when I press escape. Houdini becomes unresponsive to everything except closing it, at which point I can save it as usual and restart the file.
i have had another kind of hard to reproduce bugs ;
few times , while working on long sessions ( my perception ) , there comes a moment when Hou doesn't accept adding more nodes on networks .
prints out a message ( promise 'll save it next time ! ;) ) .. iirc , something with " number of Event / event number ... " and ' a big number ' ..
as i have 'understood' , there is nothing wrong with my scenes , because as soon as i reboot Hou and reopen the same scene : everything is fine and i can keep develop my scene . ( ! )
strange ..
.cheers
Hi!!
I have the same problem that Sanostol has; It happends when i drag a parameter to another and pop the small window to connect those channels, houdini stop to fetch my mouse an keyboard.
  • 12 years later...
  • 1 month later...
On 4/4/2024 at 3:08 PM, be9em0t said:
Old thread, but surprisingly, it's happening again on Mac Sonoma with H19.5.
Sure, complaining about mouse behavior on Mac is a bit like discovering bears poop in the wood...
Going in and out of fullscreen mode with epileptic mouse clicking in viewport solved issue on Sonoma with Houdini 20, lol, fought with this for two days straight
