Adam Ferestad Posted June 10, 2011 Share Posted June 10, 2011 I have figured out the basic modification network that I want to use for my next tutorial, but I am missing a few things and there seems to be some sort of glitch with my geo-light. The image below shows the problem I am having. All of the particles should be lit up, but for some reason they are not. I am going to do some tutorials I found to try to get the other parts of the scene that I need, but if they don't do it for me, I'll come back and ask my questions. My biggest thing is... why aren't they lighting up right? Quote Link to comment Share on other sites More sharing options...
anim Posted June 10, 2011 Share Posted June 10, 2011 can you post hip file? Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 10, 2011 Author Share Posted June 10, 2011 Sure. I have been working on it a bit, still no luck, but I switched from a popnet to copy sop with spheres as my input geometry. Same problem, but it solves some others having to do with speed. light_string.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 10, 2011 Author Share Posted June 10, 2011 (edited) ok, just did a test where I took the bucket size from 32 to 4 and it appears to be rendering everything right. So now the question is... Why? Edit: Spoke too soon, one of the spheres glitched. But only one by the looks of it. Edited June 10, 2011 by Adam Ferestad Quote Link to comment Share on other sites More sharing options...
mawi Posted June 12, 2011 Share Posted June 12, 2011 I´m no render guy but, you got the "render light geometry" switch on at the same time you are rendering the actually geometry(geo1). The light geometry and the mesh might intersect. Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 12, 2011 Author Share Posted June 12, 2011 You are absolutely right mawi. It was the geometry intersecting with the light. Thanks. Now I just need to figure out how to get the spheres so I can turn them off and leave the string. I have a few ideas, but I will have to play with it. Thank you so much. Quote Link to comment Share on other sites More sharing options...
