group parameter ( ? )
hi ,
im trying to add an ' group parameter ' to one of my OTLs , similarly with the ones that most of the built-in tools have .
obviously im failing . so ( if you ever did / know how to replicate that ) can anyone help me ?
i know i can use a ' string parameter ' , but the glory of that mini-pop-up-of-who's-available-list .. isnt available ( aparently )
the only ones that have a similar ' feature ' are the file parameters .. but i cannot find any trace of them in ParmEditor Windows .
.thanks!
If you are using the edit parm window the mini menu you refer to is redialy available.
There a several palces, but most genericaly
place a string field
place "ordered menu"
go to the "menu" tab
check "use menu"
and change type to "normal mini"
on the string field check "horizontally joi.." on parameter tab
apply.
To get it to display available groups you will liely want a script in the "menu script" radio tab in the mini menus menu tabs to pull the availible groups and then generate a list of token/labels
check "use menu"
apply.
well .. thank you for your help eyevex, but it was mostly on the ' designing side ' .
anyway , i really appreciate that .
so far i was able to script the mini-menu's interaction with the string parameter .
but i'm currently having problems with removing the latest added group in the string parameter ( ! )
illustartion : lets say i have 2 groups 1 and 2 in the string parameter . if add the 3rd and the next action is to remove it ; it fails .
any help or suggestion on this wd be appreciated .. thanks!
maybe there is a shorter way to do this ( ? )
here is the code : ( the getFinalState def is just for printing out actually )
def getFinalState():
    grpStateList = hou.pwd().evalParm( "groups_l" )
    print '- - '*10 + '+ done .'
    print grpStateList
    return grpStateList
def getGroup():
    node = hou.pwd()
    geo = node.geometry()
### "groups_l" refers to string parameter
### "groups_m" refers to mini menu items
### this part to avoid an empty element sometimes appearing in list ..
    grpState = node.evalParm( "groups_l" )
    if grpState == "":
        grpStateList = []
    else:
        grpStateList = grpState.split( ' ' )
### few boolean operation with lists here ..
    grpGeoList = [ group.name() for group in geo.primGroups() ]
    grpRemovable = set( grpGeoList ).intersection( set( grpStateList ) )
#    print 'removable .. >>', grpRemovable
    grpAddable = set( grpGeoList ).union( set( grpStateList ) ) - grpRemovable
#    print 'addable .. >>', grpAddable
    i = 0
    grpNewList = grpStateList
    for group in grpGeoList:
        if node.evalParm( "groups_m" ) == i:
            ## add group to mask ..
            if group in list( grpAddable ):
                if len( grpRemovable ) == 0:
                    grpNewList = []
                    node.setParms( { "groups_l" : group } )
                else:
                    grpNewList.append( group )
                    grpString = ' '.join( grpNewList )
                    node.setParms( { "groups_l" : grpString } )
            ## remove group from mask ..
            if group in list( grpRemovable ):
                grpNewList.remove( group )
        i += 1
    getFinalState()
@moderators : i think now ( and i had few doubts before opening this thread here ) is more appropriate to move this in the 'Scripting' section . feel free to do it ..
.cheers
  • 2 years later...
For myself i found another way. There's a some node inside my otl ("xform" for example) and i want "group" parameter from this "xform" to promote onto a digital asset level:
1. go to "Parameters -> From Node" Tab of Type Properties.
2. find that "xform" inside digital asset and select its "group" parameter.
That's all.
  • Like 2
  • 5 years later...
Here is the script I created to pre-poulate the groups menu:
# Get the currently selected group type
geometryType = kwargs["node"].parmTuple( "grouptype" )
# Get the value (points, edges, prims, etc)
for tuple in geometryType:
  type = tuple.rawValue()
menu = []
i = 0
# Get the current node
node = kwargs.get( "node", None )
# Select the groups to work with based
# on the selected group type
if node:
  if type == "points" ||:
    groups = node.geometry().pointGroups()
  elif type == "edge":
    groups = node.geometry().edgeGroups()
  elif type == "prims":
    groups = node.geometry().primGroups()
  else:
    return menu
  # Iterate through the groups and
  # add each name to the menu
  for group in groups:
    gName = group.name()
    menu.extend( [str(i), gName] )
    i += 1
return menu
