hatrick Posted July 13, 2011 Share Posted July 13, 2011 hi, i ve a problem with setting up an angular spring constraint. I'd like to change the initial rotation of my goal object. Is that possible within the contraint dop? ... the orientation of both (initial and goal rotation) should be same . Hope thats clear Thank you L Quote Link to comment Share on other sites More sharing options...
anim Posted July 13, 2011 Share Posted July 13, 2011 you can change initial rotation within the RBD object and if you set Goal Rotation on constraint to the same values, it will work that way Quote Link to comment Share on other sites More sharing options...
