How to emit fire from texture? How to light objects with fire?
chaindriver
  On 7/22/2011 at 9:27 AM, bunker said:
Adding fuel and temperature from a texture is easy, but you can't use the default sourcing method.
Have a look at this simple example : pyro_from_texture.hip
For lighting, I would use pointclouds created from a lowres render using the pcwrite function.
hope that helps :)
Thanks for all the replies guys! Especially you Bunker, for the example file.
Bunker, after getting the pointclouds, what should I do with it? Are there any existing shaders that can read in the pointcloud to light up the scene, or do I have to dig into VOPs...?
You need to build your shader in VOPs or VEX.
