Constant Opacity
Macha
I have a bunch of polygons overlapping and stacked behind each other. (think leaves on a tree or something like that)
When I render this with a point alpha value I get a kind of layered opaque effect -as expected.
However, I want the visual effect opacity to be of a constant value (a bit like a constant shader). How can I do that on a per-object basis and with the micropolygon renderer?
For naive cases you could just render out the alpha buffer with the sampling set to "closest", not "opacity". See attached.
This approach breaks quite easily though, e.g. alpha of any object behind these will have their alpha discarded..
So you would still want the color channels to have the opacity stacking behaviour, according to the point alphas, but do you want them to blend with the other geometry in the render according to their correct opacity or just the "fake" uniform opacity? Or do you just want to have the "fake" alpha for compositing?
ee_alpha.hip
hi ,
i tried with the rayhit and this is what i got :
pic 1 - the Constant1 node has a value of 0.25 which is sent nonadditively to opacity output
pic 2 - has a Constant node set to color type
pic 3 - has a Lambert node ( switchable with the above constant )
post-5487-131206440025_thumb.pngpost-5487-131206440832_thumb.pngpost-5487-131206441707_thumb.png
strangely in the pic 3 , the farthest primitive appears ( optically at least ) to be nearer . that's because of light's position ..
casting shadows over the geometry and changing light's position gave interesting but a bit strange results .
anyway here is the file ..
constantOpacity.hipnc
.cheers
