Rvb Posted September 2, 2011 Share Posted September 2, 2011 Hi everyone! I'm trying to use a texture with my rendering but I don't know if I do it the proper way. In the attachment you can see the texture colormap and the mplay colormap. I've set the gamma value to 2.2 in mplay but the texture looks flat/grayish. Is this correct? Or do I need to use some extra steps? I've created a mantra surface material and attached it to the barrel. I hope someone can give me a headsup of how to work with textures and gamma Regards, Rogier Quote Link to comment Share on other sites More sharing options...
jason_slab Posted September 2, 2011 Share Posted September 2, 2011 you need to convert your texture to linear, we usually just drop a color-correction node in the shader (after the texture node) and set the gamma to 0.45 j Quote Link to comment Share on other sites More sharing options...
sanostol Posted September 2, 2011 Share Posted September 2, 2011 (edited) you have to gammacorrect Your textures by 0.454545 either on disk or in the shading network Martin EDIT: too late Edited September 2, 2011 by sanostol Quote Link to comment Share on other sites More sharing options...
Rvb Posted September 2, 2011 Author Share Posted September 2, 2011 Ahhh great! You know I red it somewhere so I know I had to change to gamma of the material. But I didn't know where. But thanks to you guys I do know! Thanks! Rogier Quote Link to comment Share on other sites More sharing options...
