Bumpy Poly Wire?
poppy
Hi, first post here
I'm working on some lightning effect using curve and noise CHOP. I plugged the generated curves into polywire node for rendering. The question is how can I add "randomness" into wire thickness, you know, make it more electric-like.
I'm pretty new to Houdini, please don't geek me out :P .
Thanks!
Poppy
actually noise should be in -1,1 range
and the easiest way to change that range is use fit() function or in -1, 1 case fit11() function
so
fit11(noise($TX,$TY,$TZ),1,2)
will give you noise remapped to 1,2 range, etc.
but basing wire thickness on point position will produce different values as the curves will move
if that is not desired you can base it on something like $PT or any attribute
you an even create custom attribute modify it in VOP SOP or CHOPS to get your thickness values per point
then simply put $variablename to Wire Radius parameter in PolyWire SOP
so if your attribute is called "width", you will put $WIDTH in there
yes, but be careful about that too since in VEX you have many types of noises and each may have different range
which is not very helpful if you want to switch between them
according to docs:
Perlin Noise (noise): 0,1
Original Perlin Noise (onoise) -1,1
Sparse Convolution noise (snoise) -1.7,1.7
Alligator noise (anoise): 0,1
