spev Posted September 16, 2011 Share Posted September 16, 2011 Hiya Guys.. Please could someone help me out on this probably very simple question...I havent used Houdini for a couple of years and am not sure if those neurons that once held that info have died or things have changed a little in the interface... I am trying to edit a digitalAssets interface and I would like to put a tab next to the transform tab in the parameter window. My folder always goes to the bottom of the pane and not next to the transform tab at the top as I would like it. I hope someone can steer me in the right direction...and thanks in advance to any help Quote Link to comment Share on other sites More sharing options...
edward Posted September 16, 2011 Share Posted September 16, 2011 I'm not sure that you can. Try drag and dropping your folder parameter in the type properties (or edit parameter interface) windows and moving it into the middle. If that doesn't work then I guess you can't insert into the middle. Quote Link to comment Share on other sites More sharing options...
spev Posted September 16, 2011 Author Share Posted September 16, 2011 Wow thanks Edward that was quick...I think that my oinly way so far has been to make a new folder...rename it transform ...swap the parameters into this and deleting the origional transform folder...this way I can get my folder tabs to sit next to eachother...not the most elegant way ...but it works Thanks again for your kind and quick help...I have missed you guys..2 yrs too long Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 16, 2011 Share Posted September 16, 2011 I just tried this... If you put the folder onto the transform folder it will go down the bottom. Put it at the same level to get it next to the tranform tab. Worked just fine putting it directly above the subnet folder. Quote Link to comment Share on other sites More sharing options...
spev Posted September 16, 2011 Author Share Posted September 16, 2011 Thanks Sam....That did work...It didnt the first few times I tried...I just tried in a fresh scene and it worked....gosh lost more neurons than I thought... Ta Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 16, 2011 Share Posted September 16, 2011 It can be inside or outside of the folder in the same position in the list. Generally I think if you drag something past the last item in a folder, it will go outside of the folder. To get something as the last item in a folder, you need to put it second to last and drag the last to second to last Quote Link to comment Share on other sites More sharing options...
spev Posted September 16, 2011 Author Share Posted September 16, 2011 thanks again sam for the kind advice.....would you possible know how to zoom out of the view mask in houdini...I can never see the whole thing? Ta Quote Link to comment Share on other sites More sharing options...
sam.h Posted September 16, 2011 Share Posted September 16, 2011 (edited) I don't know what you mean I am quite sleep deprived :/ Edited September 16, 2011 by sam.h Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted September 16, 2011 Share Posted September 16, 2011 (edited) My folder always goes to the bottom of the pane and not next to the transform tab at the top as I would like it. OMG! Tell me about it. This drove me crazy for a long time before I learned the obvious. Under the create parameters, click to highlight which control you want to insert (i.e. folder), under the existing parameters, click the control it should appear directly under (in this case "transform"), then click the right arrow in the middle of the two columns to add the new folder. It will appear next in the list of tabs. Sounds simple, but I was always dragging and dropping my controls and they never went in the right place. EDIT: Sorry, the above doesn't work as expected. You have to drag drop it between two folders, but below is what I was talking about. For example. Folder +- control 1 +- control 2 +- control 3 If you drag and drop a control, it won't go into the folder under control 3. It will be placed outside the folder. You can drop it between control 2 and control 3, and then re-arrange them. This is what I was doing for a long time. The easy trick, select control 3, and then use the right arrow. The new control will be appended to that folder. yea, it's a noob thing but that took me a while to figure out. Edited September 16, 2011 by hopbin9 Quote Link to comment Share on other sites More sharing options...
spev Posted September 16, 2011 Author Share Posted September 16, 2011 ta guys. This forum still rocks. Making assets is a little more fun now. Quote Link to comment Share on other sites More sharing options...
