Grouping Points
I want to make a procedural setup so that my first point is put into a separate group with each point on my spline.
I've been trying to use the partition sop which gives me the group for each point but i'm unsure how i can add the first point to each of these groups?
I've made the set up manually but i would like it to be more flexible and procedural.
Thanks for any help.
Here's a pic to show the effect i'm after.
add_groups.tiff
Edited by chrisperry05
Hi guys,
I join the post with other questions about grouping points.
I have a surface and I have refined its topology using a clothRefine. Because I will need to use the wireframe structure and not the surface, I'm trying to brake the repetitiveness of the triangulation by selecting the points generated by the clothRefine, collect them in different group SOP and reconnect them using an add SOP by group.
Is it possible to select/sort the points generated by the clothRefine in order to keep the new connections from the add SOP shorter and more localized?
Would it also be possible for each and every group to have the perimetrical points always selected?
I have created a simple scene to give you a reference of what I'm talking about.
Any suggestion would be great.
SimpleScene.hipnc
