specular and reflection passes houdini 11
Hi all,
I am having trouble in rendering specular and reflection passes in Houdini.
I have tried and I am not sure If I am right.
For some reason the vex variables for reflection and specular pass doesnt work properly
Please have a look at my attached file and please correct me if the spec and refl passes are wrong
Thank you very much.
passes_v.hipnc
Hi all,
You set MantraROP to render with reflections take, but that take has deep planes disabled. It has also reflection of lights turned off (on a shop) along with room's vm_renderable shoot down. So, a little mess there. Other than that, all seems to be working! :)
What about specular pass?
at times spec pass with the use of image planes doesnt work.have i did the specular pass correctly?
