DBaciu Posted March 14, 2013 Author Share Posted March 14, 2013 This are the edges (hips, valleys, ridges) as geometry. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted March 14, 2013 Share Posted March 14, 2013 Very nice, You could also do a straight skeleton on the ridges themselves so they don't self intersect. Quote Link to comment Share on other sites More sharing options...
DBaciu Posted March 14, 2013 Author Share Posted March 14, 2013 Thank you, Kim. What do you mean? They don't intersect (see image 001). There is a problem, is the intersection itself (the joint). It's a kind of mean thing (thank god it only appears at big differences in slope between joining edges. I don't know how this problem would be solved in the real life (a real construction). See the images. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted March 14, 2013 Share Posted March 14, 2013 It is not these sections I'm talking about. It is what you can see in complex2.jpg when ribbon is thick it seems to intersect itself when you have strong curvature. Quote Link to comment Share on other sites More sharing options...
DBaciu Posted March 14, 2013 Author Share Posted March 14, 2013 I understand now, but to run the straight skeleton on those things would be utterly overkill. That thing is just a particular case caused by a too acute angle on the main (path) shape. Or to beefy of a profile. A Schwarzenegger of a profile. But it's an idea to be noted, maybe for further development. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted March 14, 2013 Share Posted March 14, 2013 On 3/14/2013 at 9:12 PM, Bandaciu said: I understand now, but to run the straight skeleton on those things would be utterly overkill. That thing is just a particular case caused by a too acute angle on the main (path) shape. Or to beefy of a profile. A Schwarzenegger of a profile. But it's an idea to be noted, maybe for further development. In case of building roofs this is true. But I see this tool as being very useful as well for creating ornaments for example, where very thick ribbons could be required. I wouldn't use it to create rooftops only. Is this inspired on the work of Sven Havemann & Dieter W. Fellner Generative Modeling Language? Quote Link to comment Share on other sites More sharing options...
DBaciu Posted March 14, 2013 Author Share Posted March 14, 2013 1. Indeed, I used this tool to experiment modeling all kind of stuff. 2. No, it is not, but that seems very interesting. Quote Link to comment Share on other sites More sharing options...
DBaciu Posted March 14, 2013 Author Share Posted March 14, 2013 Quote Link to comment Share on other sites More sharing options...
DBaciu Posted July 17, 2013 Author Share Posted July 17, 2013 Hello guys, I have an update to the roof generator that I want to show you. Now it can make gabled roofs. Gables doesn't need to be on rectangular sides (90 degrees etc), they can be anywhere. Also multiple (chained) gable walls are supported. See the images. I marked with red the sides that will become gables. There are a few minor problems to be solved, though. Ps: in case you don't know, this tool has been on Orbolt since April. In case you played with it like for example Freaq wanted, maybe some comments are in order... Quote Link to comment Share on other sites More sharing options...
old school Posted July 18, 2013 Share Posted July 18, 2013 This thing is an architect's dream! Makes the roof generator in Revit look simplistic. Absolutely nutbar! Quote Link to comment Share on other sites More sharing options...
DBaciu Posted July 18, 2013 Author Share Posted July 18, 2013 Thank you very much! I'm honored! Quote Link to comment Share on other sites More sharing options...
DBaciu Posted August 5, 2013 Author Share Posted August 5, 2013 Well, I managed to turn this into a weighted solution. Now every edge can have a different angle (even negative ones, which goes outside of the contour) Quote Link to comment Share on other sites More sharing options...
DBaciu Posted August 5, 2013 Author Share Posted August 5, 2013 Another example... Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted November 20, 2013 Share Posted November 20, 2013 This is insanely awesome! Congrats Did you end up making an OTL out of it? Did you publish it? Quote Link to comment Share on other sites More sharing options...
DBaciu Posted November 24, 2013 Author Share Posted November 24, 2013 Thank you very much! Well, if you are talking about this last post with the weighted solution then no, it is not completed for now, it needs some more work to be usable. I hope I'll be able to finish it soon. If you are talking about the whole thread then yes, an older variant of this this roof generator is on Orbolt for quite some time now Quote Link to comment Share on other sites More sharing options...
Parnika Posted December 2, 2013 Share Posted December 2, 2013 Awesome.. Quote Link to comment Share on other sites More sharing options...
hyperforce Posted January 28, 2014 Share Posted January 28, 2014 (edited) I'm looking into creating something using reversed straight skeleton. However no-one but you seems to have found a workable method within Houdini that I can tell. Is there any chance you would write a tutorial or release your straight skeleton method. I checked your file on orbolt, but its a file that even if I were to pay 130 dollars It won't allow me to learn from it. I'd rather pay for a tutorial than for a tool I can't learn from. Edited January 28, 2014 by hyperforce 1 Quote Link to comment Share on other sites More sharing options...
DBaciu Posted January 29, 2014 Author Share Posted January 29, 2014 Hello. Lately I received a few calls from people asking me to make a tutorial or release this method in some way (maybe unlock the asset). And yes, I was (I am) thinking of making a tutorial but this will take some time. Unlocking the asset is another possibility, I'm not sure... What do you mean by "reversed straight skeleton" and what you'll be using it for (if you don't mind the question)? Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted January 31, 2014 Share Posted January 31, 2014 You can add me to the list of people being highly interested in an tutorial on creating roofs (or any type of complex real world geometry) procedurally. Quote Link to comment Share on other sites More sharing options...
freaq Posted January 31, 2014 Share Posted January 31, 2014 +1 would love a tutorial!maybe contact CMIFVX? (I have their contact info should you need it) 1 Quote Link to comment Share on other sites More sharing options...
