Benyee Posted October 26, 2011 Share Posted October 26, 2011 I just got a simple approach to cut off wire object in DOPs,fake version. Any other idea to make cutting process flexible,robust and automatic,how to do,thanks.wire_cutter.hip Quote Link to comment Share on other sites More sharing options...
NicoZ Posted October 26, 2011 Share Posted October 26, 2011 Hi Benyee, I recently had the same interest in cutting wires and research some things. I did it by spliting the wire geo in two, then used a spring constraint attached to the points where both join and finally i adjusted the strengh limit of the constraint. I made a little system to generate multiple wires and assign a "break zone" where its possible the wires to break. I uploaded some videos here if you want to see: And here is the scene with every tests i done with wires: Hip File Hope you find this useful! Quote Link to comment Share on other sites More sharing options...
anim Posted October 26, 2011 Share Posted October 26, 2011 it was also discussed here http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=23062 Quote Link to comment Share on other sites More sharing options...
