3dbeing Posted November 5, 2011 Share Posted November 5, 2011 I'm trying to understand how the pciterate works and I'm definitely missing some of the finer details. Wondering if anybody can shed some light... right now I am simply trying to add up an attribute, just as an exercise. In this case point number over 4 points. Final answer would be 6. a) Why does my vop error saying pcimport is called outside of loop? It is definitely inside the while loop node... While my final result is correct, how does point #1 have a value of 2, and #2 a value of 4? I would expect values of 0 1 3 and 6. thanks for any help, -=3db hmmmm it seems while writing this, some magic happened and the vop no longer throws the warning.... peculiar... but still curious about values of 0 2 4 and 6... pcopen.hipnc Quote Link to comment Share on other sites More sharing options...
sanostol Posted November 5, 2011 Share Posted November 5, 2011 Hi, You have to pack the pcimport into a ifthenNetwork, because the texcture handle can be empty and so pcimport doesn't work correctly see attached file Martin pcopen_mod.hipnc Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted November 5, 2011 Share Posted November 5, 2011 You can search in Houdini Exchange for: "Hip Files From Point Cloud Presentation May 11th 2005" There are some great examples in there. Quote Link to comment Share on other sites More sharing options...
3dbeing Posted November 6, 2011 Author Share Posted November 6, 2011 Thanks Sanostol, But this method merely creates a new attribute, I am trying to add up all the point attributes. I thought each point would be the sum of all the points before it. Fabiano, I looked on there, but i couldn't find anything about it, well i found a page but no links to files. Do you have a link? Thanks. -=3db Quote Link to comment Share on other sites More sharing options...
sanostol Posted November 6, 2011 Share Posted November 6, 2011 mh, I don;t get what You are trying to do, If You want to sum up all attributes, You have to increase the radius and the pointcount of the pcopen. keep in mind that every point is just processed for its own, there is no sequential processing of the points Martin Quote Link to comment Share on other sites More sharing options...
3dbeing Posted November 6, 2011 Author Share Posted November 6, 2011 mh, I don;t get what You are trying to do, If You want to sum up all attributes, You have to increase the radius and the pointcount of the pcopen. keep in mind that every point is just processed for its own, there is no sequential processing of the points Martin hmmm, i guess i misunderstood pciterate then. ok thanks... Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted November 29, 2011 Share Posted November 29, 2011 Fabiano, I looked on there, but i couldn't find anything about it, well i found a page but no links to files. Do you have a link? Thanks. Yes. I do. The web page: http://www.sidefx.com/exchange/info.php?fileid=208&versionid=208 The files: http://www.sidefx.com/exchange/download.php?fileid=208&versionid=208&type=OTL It's compressed as a "tar.gz" file extension. Hope you can open it. Quote Link to comment Share on other sites More sharing options...
