Houdini python
Hello world
Came up with a question.
I want to access hou modules from a regular python shell
http://www.sidefx.com/docs/houdini11.1/hom/commandline
and after this when i test if the code snippet whether worked
import hou
>>> import hou
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "c:\Program Files\Side Effects Software\Houdini 11.0.547/houdini/python2.
6libs\hou.py", line 18, in <module>
import _hou
ImportError: DLL load failed: %1 is not a valid Win32 application.
I have also followed the code snippet given below
import os
 import sys
 from os import environ as env
 env.has_key('HFS')
 &gt;&gt;&gt; True
 sys.path.append(os.environ['HFS'] + '/houdini/scripts')
 sys.path.append(os.environ['HFS'] + '/houdini/python2.6libs')
  import hou
import _hou
It would be really great if any one can help me out.
thanks
  • 3 years later...
Hi Guys
I realise this is an old post, but it seems the closest to my own issue.
 File "C:\Program Files\Side Effects Software\Houdini 14.0.361\houdini\python2.7libs\hou.py", line 18, in <module>
    import _hou
ImportError: DLL load failed: The specified procedure could not be found.
I found that _hou is effectively a python dll, so if I understand correctly that is the dll causing the error. From what Edward says above I think the problem maybe the compiler version used to create _hou?
I did go down a track and found there are mismatch dlls : Houdini's - msvcr110.dll and Pycharms msvcr100.dll
I have no idea how to resolve that if it is in fact the problem. Any help would be greatly appreciated.
Thanks
Windows 7 Pro 64
Python 2.7.5
PyCharm 4.5 Community
Houdini 14.0.361 Apprentice
Edited by NSDesign
