changing digital asset paramteters
hatrick
hey,
I wonder how to resave changes of a digital asset like new parameters a.s.o. for a new version of the asset ...
Thank you
L
SOLVED; There is a difference between the properties -access in the parameter view and the one via "right mouse" and "tye properties" on the asset node itself?!
Edited by hatrick
Yes. Say you put down two different copies of your HDA. They are different nodes but are the same TYPE. Editing the Operator Type Properties dialog will change ALL the nodes that use your HDA type (in this case both of them). Using Edit Parameters, you are only changing that particular node (ie. one of them).
