Stremik Posted October 17, 2003 Share Posted October 17, 2003 I wanted to install "FilmGimp" but it appears so that it needs GLIBC-2.3 and I have GLIBC-2.2 (I'm running RH7.3) So I was wandering. If I go ahead and upgrade GLIBC will everything be OK or I will break my Linux installation? Quote Link to comment Share on other sites More sharing options...
tallkien Posted October 18, 2003 Share Posted October 18, 2003 I upgraded mine in Gentoo. Not the same versions but linux didn't break....yet Quote Link to comment Share on other sites More sharing options...
Mcronin Posted October 18, 2003 Share Posted October 18, 2003 I'm also using Gentoo, and I had upgraded it on an older version of RedHat to run CinePaint. It worked fine in both cases. Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 18, 2003 Author Share Posted October 18, 2003 The reason why I'm asqing this is that I remember coming across a post on "justlinux" forums awhile ago where someone asqed a similar question. The answer was that many apps and modules would stop working. From my point of view, if this was true, it wouldn't be the Linuxlike. Being in doubt, I decided to confirm it with you guys. BTW. Could you please outline the process of how to do it please. I'm still very new to Linux. Quote Link to comment Share on other sites More sharing options...
tallkien Posted October 18, 2003 Share Posted October 18, 2003 rpm -Uvh ??? I think it may be possible to keep the old one and still upgrade. Gentoo allows this in some cases. Not too experienced with that myself so I don't want to lead you astray. get on one of the linux irc channels. those guys are pretty helpful. Installation and upgrade is pretty automated on Gentoo and quite unlike any other linux distro, so the procedure would not be the same. Given glibc is such a core component in linux I personally wouldn't want to play around without checking it out thouroughly. I'd recommend gentoo to anyone but if you must keep rh7, go right on ahead. On a hunch I believe the most you would need to do is upgrade or reinstall some of the dependent software, but please don't take my word for it Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 18, 2003 Author Share Posted October 18, 2003 Maybe I should just switch to RedHat 8!? How does Houdini work with it? Quote Link to comment Share on other sites More sharing options...
tallkien Posted October 18, 2003 Share Posted October 18, 2003 Houdini should work just fine with rh8, Works fine with 9 too- was using it before i switched to gentoo. If you can get your hands on gentoo, give it a try. Teaches you a lot about how linux works. I'm a newbie myself and gentoo has helped me come to terms with linux, dare I say even tame it to some extent, Besides I've never gone this long without needing to reinstall linux Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 19, 2003 Author Share Posted October 19, 2003 That's it! I'm curious. I'm gonna install "Gentoo" Tell me tho, which one do I need? I looked at an FTP mirror and found multiple distros. "athlon-xp", "basic", "i686", "pentium3", pentium4", "x86". Certanly I understand that both "pentiums" are ruled out since I'm have an Athlon mashine. What about the rest four? Which one is better for me? Indeed, my question probably sounds dumb but I just want to be shure! Also. Should I get the distro from folder called "livecd" or "stages"? Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 19, 2003 Author Share Posted October 19, 2003 Ooops! Never mind. Figured it out. Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 19, 2003 Author Share Posted October 19, 2003 Holy crap! Just read the instructions how to install Gentoo......... It's scary! Oh well. I have the whole night ahead of me. Is there ainy advices/tricks you wanna give me before I plunge myself into death leap? (Damn, I'm gonna enjoy it!!! ) Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 19, 2003 Author Share Posted October 19, 2003 All right. First problem. I can't login to "Live CD". I type passwd root at the prompt and enter a new password but it doesnt' let me proceed with installation giving me some lame explanations like "password not long enough" or "not enough different caracters in password" etc. I'm shure I do something wrong here. tallkien, can you help me out here please? Quote Link to comment Share on other sites More sharing options...
edward Posted October 19, 2003 Share Posted October 19, 2003 That's normal. For security reasons, most Unix systems require passwords that are not prone to easy guessing. For "password not long enough", make sure that you've picked something that is around 6-8 characters in length. For "not enough different characters in password", make sure that you don't have repeating characters or at most two characters which are the same. Some tips I've used in the past are: - Use some digits - Pick a phrase and use the first letter of each word Quote Link to comment Share on other sites More sharing options...
tallkien Posted October 25, 2003 Share Posted October 25, 2003 Holy crap!Just read the instructions how to install Gentoo......... It's scary! Oh well. I have the whole night ahead of me. Is there ainy advices/tricks you wanna give me before I plunge myself into death leap? (Damn, I'm gonna enjoy it!!! ) Holy crap!Just read the instructions how to install Gentoo......... It's scary! Oh well. I have the whole night ahead of me. Is there ainy advices/tricks you wanna give me before I plunge myself into death leap? (Damn, I'm gonna enjoy it!!! ) If its any consolation it took me 4 attempts to get it right, Some thing or the other would go wrong. But on the upside each time I learned something new about the voodoo of linux. Its been thouroughly worth it Quote Link to comment Share on other sites More sharing options...
Stremik Posted October 25, 2003 Author Share Posted October 25, 2003 That's what I'm going trough right now But the ability to go online to read the most recent docs is AWSOME!!! This "links" command is just........I have no words! Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 7, 2003 Share Posted November 7, 2003 Ok, what's up with gentoo guys. I've been following along here for a couple months of gentoo. You are all still happy with it? No thoughts of moving on to RH9? Just curious. Quote Link to comment Share on other sites More sharing options...
tallkien Posted November 7, 2003 Share Posted November 7, 2003 I moved from RH9 and yes, Super Happy with it! Quote Link to comment Share on other sites More sharing options...
