magneto Posted November 21, 2011 Share Posted November 21, 2011 I was trying a small idea with a vex shader network to accomplish rotating UVs using Time. But I couldn't find any VOP(?) for this? Basically I want the UVs to rotate through time. So they will be animated but inside the shader, not via keyframes. Just a simple idea I wanted to try to learn about the vex shaders, etc. Thanks guys. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 21, 2011 Share Posted November 21, 2011 I was trying a small idea with a vex shader network to accomplish rotating UVs using Time. But I couldn't find any VOP(?) for this? Basically I want the UVs to rotate through time. So they will be animated but inside the shader, not via keyframes. Just a simple idea I wanted to try to learn about the vex shaders, etc. Thanks guys. you have shading time in your global variables, doesn't it work? Quote Link to comment Share on other sites More sharing options...
magneto Posted November 21, 2011 Author Share Posted November 21, 2011 you have shading time in your global variables, doesn't it work? Thanks Ehsan, found it. I was looking at their existing globals which were separated. So one node had "surface position", the other had "parametric s coordinate". I expected all the globals to be in the same node. So I now saw it when I added the Global variables node. Quote Link to comment Share on other sites More sharing options...
symek Posted November 21, 2011 Share Posted November 21, 2011 (edited) Thanks Ehsan, found it. I was looking at their existing globals which were separated. So one node had "surface position", the other had "parametric s coordinate". I expected all the globals to be in the same node. So I now saw it when I added the Global variables node. VEX is generally timeless. The time from globals Vop is a normalized sample time in shutter opened period. To animate anything in VEX you need to provide time parameter externally, like any other user's parameter. So you make a float, animate it with channel, but VEX sees a single value of evaluated channel at a current *Houdini* time. Edited November 21, 2011 by SYmek Quote Link to comment Share on other sites More sharing options...
magneto Posted November 21, 2011 Author Share Posted November 21, 2011 VEX is generally timeless. The time from globals Vop is a normalized sample time in shutter opened period. To animate anything in VEX you need to provide time parameter externally, like any other user's parameter. So you make a float, animate it with channel, but VEX sees a single value of evaluated channel at a current *Houdini* time. Thanks Symek. Can't wait to try this out. Quote Link to comment Share on other sites More sharing options...
