How to bring up the Houdini Console window?
magneto
Writing a SOP how? Python? HDL? Where are you starting Houdini from? I'm pretty sure it works if you use the Start Menu. The other issue could be that your SOP is not recooking.
Sorry it's python. I always use the start menu. Do you know how I can tell it's not recooking?
If it's a Python SOP, don't the print statements go to the last Python Shell window you have open? You can open up the Performance Monitor to see if your SOP is recooking. To force it to recook, click on its bypass flag twice (assuming that it is displayed).
Thanks, I have a python shell open, but how can I show intermediate values in my python SOP there? Also why do you recommend against using print in python SOPs? I only use it for debugging because I couldn't find any other way. I just checked yeah my SOP was cooking properly, but it's good to know this bypass twice trick.
In Main Preferences=>Nework Editor... =>Node Tiles
check highlight Currently Cooking Node
Thanks man, should come in handy.
