help! this project just crash houdini
ouyeantai
this scene just crash my houdini 11.1.143.
1.open the envdesign.hip
2.select the 'skydoom node' from '/obj' then assign the 'skydoom material' from '/shop' to it. And it
will crash houdini.
at the first I thought it was the texture what cause it crash.But when i change the texture. it still
crash.
I debuging for days and can find out what's happening.
my meachine: CPU: core2 x9100. videocard:quadro fx 770m. memory: 6GB. OS:windows7 x64bit.
when it crash my houdini and i check the memory usuage. it only use 290MB. so memory may not be the issue.
but it gave me this message anyway:
envdesign - Copy2.zip
Edited by ouyeantai
It crash my H11.1.67 also
But it works on H12.0.461. At least it doesn't crash, but every node in you skydoom shader has a warning : "errors or warning encountered during vex compile".
Edit : as a workaround try to swith to wireframe mode before assigning your shader. It works for me (H11). I guess it's an Ogl issue...
Edited by ben
