python parm type
ivan
is there any way to determine if a three dimansional tuple is a point or a color?
i.e:
>>>mytuple = hou.node("shop/mythingy").parmTuples()[10]
>>>mytuple.name()
'foo'
>>>len(mytuple)
3
great. now, is the UI for mytuple a "point" or is it a "color"? is it possible to determine this?
hou.ParmTemplate[1] will lead you the way.
The look of tge parmTemplate tells you if it's a color or a float[3] widget.
The type of the parmTemplate tells you if it's a toggle or an integer.
>>> hou.parm('/obj/null1/parm1').parmTemplate().type()
parmLook.ColorSquare
>>> hou.parm('/obj/null1/parm2').parmTemplate().type()
parmLook.Regular
>>> hou.parm('/obj/null1/parm3').parmTemplate().type()
parmTemplateType.Int
>>> hou.parm('/obj/null1/parm4').parmTemplate().type()
>>> hou.parm('/obj/null1/parm4').parmTemplate().type() == hou.parmTemplateType.Int
True
[1] http://www.sidefx.com/docs/houdini11.1/hom/hou/ParmTemplate
Edited by rdg
