sparkChan Posted January 16, 2012 Share Posted January 16, 2012 hi, can I assign a noise map to the intensity of light like maya. look below picture: thanks. Quote Link to comment Share on other sites More sharing options...
br1 Posted January 16, 2012 Share Posted January 16, 2012 hi, can I assign a noise map to the intensity of light like maya. look below picture: thanks. there is a projection map slot in the Spot Light Options tab. You can put a texture file there or the output of a comp using op:/path/to/your/node Quote Link to comment Share on other sites More sharing options...
