Deleting points to break up a primitive.
hopbin9
Hi, got a problem.
I have a Circle SOP (arc type is open) set as a polygon and I want to delete every N'th point so that I have a dashed line circle.
So I Group every N'th point, but when I Blast SOP that group it deletes the points but it's still all one connected primitive with some missing points.
I want to delete the points and break it up into multiple primitives so it looks like a dashed line.
I can't seem to figure it out.
Thanks,
In fact, if you make a circle line and use
0e1 0e3 0e5
as the group input in the dissolve node you can do it. There must be a more procedural way with this weird syntax though... Perhaps a little python string writing thing...
Edited by Macha
  • 2 years later...
Is there a more general solution to this when you are deleting points in an irregular manner? I have a bunch of curves crisscrossing an area, have selected some points via a group, and want to delete them, breaking the curves at that point, but they just connect from their nearest remaining points.
Edited by Dispel
  • 6 years later...
Checking in 6 years later to say that the way i found to do this was:
to find a way to group the edge (i used by length) and
use a dissolve sop on that edge
delete and blast wernt working, makes me think i need to go back and learn what these guys do under the hood a bit better.
On 1/19/2012 at 12:14 PM, hopbin9 said:
Hi, got a problem.
Thanks,
nah...it's all in the add,
add to delete geo then reconstruct ....hint every 2 !! c'mon you can do it.
oh sheesh, this thread is older than father time...why did i even bother with it ? NFI.
Edited by Noobini
