hopbin9 Posted January 19, 2012 Share Posted January 19, 2012 Hi, got a problem. I have a Circle SOP (arc type is open) set as a polygon and I want to delete every N'th point so that I have a dashed line circle. So I Group every N'th point, but when I Blast SOP that group it deletes the points but it's still all one connected primitive with some missing points. I want to delete the points and break it up into multiple primitives so it looks like a dashed line. I can't seem to figure it out. Thanks, Quote Link to comment Share on other sites More sharing options...
Macha Posted January 19, 2012 Share Posted January 19, 2012 In a dissolve node you can write p0, p1, etc and delete segments. It doesn't quite do what you want though and I'm thinking you could somehow split up your curve so that each segment is a curve. Quote Link to comment Share on other sites More sharing options...
Macha Posted January 19, 2012 Share Posted January 19, 2012 (edited) In fact, if you make a circle line and use 0e1 0e3 0e5 as the group input in the dissolve node you can do it. There must be a more procedural way with this weird syntax though... Perhaps a little python string writing thing... Edited January 19, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted January 19, 2012 Share Posted January 19, 2012 (edited) Maybe like so: `pythonexprs("' '.join(['0e'+str(a*2) for a in range(100000)])") Edited January 19, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
3dbeing Posted January 19, 2012 Share Posted January 19, 2012 circle Sop -> Delete/keep points checked -> add sop/polygon tab/Groups of npoints.... Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted January 19, 2012 Author Share Posted January 19, 2012 Thanks guys, Both your methods worked perfectly. Quote Link to comment Share on other sites More sharing options...
Dispel Posted February 7, 2014 Share Posted February 7, 2014 (edited) Is there a more general solution to this when you are deleting points in an irregular manner? I have a bunch of curves crisscrossing an area, have selected some points via a group, and want to delete them, breaking the curves at that point, but they just connect from their nearest remaining points. Edited February 7, 2014 by Dispel Quote Link to comment Share on other sites More sharing options...
SimonHarrisCo Posted May 22, 2020 Share Posted May 22, 2020 Checking in 6 years later to say that the way i found to do this was: to find a way to group the edge (i used by length) and use a dissolve sop on that edge delete and blast wernt working, makes me think i need to go back and learn what these guys do under the hood a bit better. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 25, 2020 Share Posted May 25, 2020 (edited) On 1/19/2012 at 1:14 AM, hopbin9 said: Hi, got a problem. I have a Circle SOP (arc type is open) set as a polygon and I want to delete every N'th point so that I have a dashed line circle. So I Group every N'th point, but when I Blast SOP that group it deletes the points but it's still all one connected primitive with some missing points. I want to delete the points and break it up into multiple primitives so it looks like a dashed line. I can't seem to figure it out. Thanks, Expand nah...it's all in the add, add to delete geo then reconstruct ....hint every 2 !! c'mon you can do it. oh sheesh, this thread is older than father time...why did i even bother with it ? NFI. Edited May 25, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
