sweeping geometry
exarhos2003
I got the final product I was looking for, but I would like to know why
are the points twisting/rotating the way they are. I'm animating the arc angles in the circle sop so that the geometry opens up in two directions. That is what I want, but as you can see from the bottom two images its also twisting the points.The green arrows are good, the red are bad.
In the bottom two images I changed the geometryso the twisting could be more visable.
Any thoughts,
christopher
I rebuilt the network. :lol:
What I am doing is, I have a curve that I am sweeping along the circle, to open up at one end.
When I rebuilt the network, I made my curve in the xy plane and the circle in the xz plane. For some reason this worked.
Hopefully it doesnt happen again.
Also, rather than use sweep sop, i went to particles and attached the curve to the points, this way i have so much more control for some of the effects i want to due.
Im also trying to control the alpha based on the PR or point position, I may be back for help
christopher
