Thirdeye Posted August 5, 2002 Share Posted August 5, 2002 Hi folks, Now I know most of you are poly modelers, but does anyone out there know why the Join SOP makes a smooth nurbs model look like a low res poly mesh? It still renders correctly but looks like rubbish in the viewport and hinders further modelling. Does this still happen in 5.5 Jason? Any info or workaround on this would be great. Ian Quote Link to comment Share on other sites More sharing options...
plan9 Posted August 5, 2002 Share Posted August 5, 2002 did you try to resample or refine? Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted August 5, 2002 Share Posted August 5, 2002 Hi Ian, I believe that the rough looking NURBS are attributed to the level of detail. Houdini's level of detail is set to 1 by default. You can change this LOD by going to the Display Option (or hit the 'd' key in the viewport) and to go the Viewport tab. The higher the LOD is, the slower your scene will be when it gets more complex. Cheers, Alex Quote Link to comment Share on other sites More sharing options...
Thirdeye Posted August 5, 2002 Author Share Posted August 5, 2002 Thanks Alex, you are quite right. It's good to know it's not a bug in my version or anything like that. Cheers Ian Quote Link to comment Share on other sites More sharing options...
