eirik.m Posted January 27, 2012 Share Posted January 27, 2012 (edited) Hello friends! I have this simulation cahced out disk. And when I try to import it back in to Houdini via the file SOP I get an error: "unable to read file". I don't have a clue why it can't read. The sim finished without problems and there is no compression for the files. Is the files just broken? It's nice that the files are filled with errors after a 24 hour simulation Thanks for answers! Eirik Edited January 27, 2012 by eirik.m Quote Link to comment Share on other sites More sharing options...
eetu Posted January 27, 2012 Share Posted January 27, 2012 I have this simulation cahced out disk. And when I try to import it back in to Houdini via the file SOP I get an error: "unable to read file". I don't have a clue why it can't read. The sim finished without problems and there is no compression for the files. Is the files just broken? If you saved the data in DOPs, it's probably .simdata, and should be read in DOPs with the File DOP. File SOP reads and write object data, they are different beasts. Quote Link to comment Share on other sites More sharing options...
eirik.m Posted January 27, 2012 Author Share Posted January 27, 2012 Thak you very much eetu! I shall try to read it inside the DOPs Quote Link to comment Share on other sites More sharing options...
