Vivo3d Posted January 30, 2012 Share Posted January 30, 2012 hello guys, this is my first post/thread in this forum. I read this is the best place for houdini and so here I am. I'm having a problem while playing a naiad particle system in houdini and get the following error: a memory allocation error occurred probably due to insufficient memory Fatal error: segmentation fault my question is, is this error related to my system memory (16gb and houdini only uses 8gb when I get the error message) or to my gpu memory (1gb geforce). I read somewhere else that segmentation errors are due to gpu memory but I want to be 100% sure before I get a new gpu or system memory. thanks a lot for your help and tips dan Quote Link to comment Share on other sites More sharing options...
Johanvfx Posted February 8, 2013 Share Posted February 8, 2013 (edited) I am having a separate issue, but it's giving me the same error message. Houdini has worked flawlessly on my desktop for months, and yesterday it crashed during some easy modeling, and it won't start back up. I have tried Houdini 12.1.33 and Houdini 12.1.185 (both apprentice), and they give me the same error. "A memory allocation error occured, probably due to insufficient memory" OS: Win 7 CPU: i7 2600k 3.4ghz GPU: ATI Radeon 6990 I've restarted and reinstalled. I threw support an e-mail, but if anyone have experience with this, please let me know. Is there a magic temp-folder I can just delete and reset, that'd be nice. When support gets back to me, I'll post the answer here. Thanks, - Johan Edited February 9, 2013 by Johanvfx Quote Link to comment Share on other sites More sharing options...
edward Posted February 9, 2013 Share Posted February 9, 2013 Look for the houdini12.1 directory in your user directory ... ie. c:\Users\username\Documents\houdini12.1 ... try renaming houdini12.1 to houdini12.1.old and then start Houdini ... If that doesn't work, maybe your video driver got updated and it's not liking that? Quote Link to comment Share on other sites More sharing options...
Johanvfx Posted February 11, 2013 Share Posted February 11, 2013 I deleted the houdini12.1 folder and it actually solved the problem. Thank you edward! Quote Link to comment Share on other sites More sharing options...
