pyro doubt
Hi 2 simple beginner questions
1) what is a force scale in the pyro solver? what change does it bring to the simulation?
2) and what is the force scale mapping under the turbulence tab? what it does? what change does it bring to the simulation?
thanks
1) I`m not sure about force scale. I believe you can uniformly scale external forces alltogether like gravity, wind, etc... and extra force fields.
2) with force scale mapping you can adjust where the turbulence supposed to act more/less. It`s like a mask on the turbulence scale.
You can set up your turbulence not to affect the entire simulation uniformly, but to affect different parts of the simulation differently based on a field.
For example you can add less turbulence where density is less, or add more turbulence to areas where the smoke is warmer.
