notawhale Posted October 9, 2012 Share Posted October 9, 2012 (edited) Hi! I made some change in Surface Uber Shader. // Version 0.66// 02.10.2012// Added export Diffuse, Specular per-light// Version 0.67// 03.10.2012// Added Opacity By Fresnel. (Can by helpfull for compositing then use opacity on object without refraction)// Version 0.68// 05.10.2012// Added Export Position and Normal in world transorm (Can by helpfull for Relighting)[/CODE][CODE]export vector exportPositionexport vector exportNormal[/CODE]shader.zip Edited October 9, 2012 by notawhale Quote Link to comment Share on other sites More sharing options...
jim c Posted October 10, 2012 Share Posted October 10, 2012 Unfortunately I wouldn't quite know where to start with PBR. I've done a little bit with it by extending exist shaders in VOPs, but that was really simple. In code I wouldn't know what I need to fiddle with. Have you tried PBR in H12? I have been blown away at how fast it is, at least so far. Anyhow, I'll keep fiddling with it! Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 10, 2012 Share Posted October 10, 2012 I didn`t write PBR shader, but many information about it in documentation: http://www.sidefx.com/docs/houdini12.1/vex/pbr Quote Link to comment Share on other sites More sharing options...
old school Posted October 10, 2012 Share Posted October 10, 2012 The whole point behind this shader is to use micropoly scan-line biased rendering with all the point cloud bells and whistles to avoid casting any rays at all and implementing fast GI methods to keep render frames in check. PBR does it's own unbiased render thing and is a completely different beast with no illuminance loop what so ever. The default Mantra Surface shader incorporates some shared shading models between the biased (pbr) and unbiased (micropoly and raytrace) render engines in Mantra but with all things like this, there are some compromises set. I'd say that PBR is winning the decisions in the Mantra Surface shader wrt optimizations and development imho. This is where this shader shines in it's complete support of biased rendering and GI techniques. I love it! It certainly cuts against the current trend toward unbiased rendering. Now we need a complementary no holes barred PBR shader with complete disregard for biased rendering as well, with it's own unique terminology completely separate from the biased shader. Specular (biased) vs Reflection of Lights (unbiased) describing the same thing, etc. I like the organization of this shader development environment and is a good example of coding your own uber shader without using VOPs if you so wish. Quote Link to comment Share on other sites More sharing options...
slayerk Posted October 11, 2012 Author Share Posted October 11, 2012 another example: https://vimeo.com/51202781 Quote Link to comment Share on other sites More sharing options...
jim c Posted October 12, 2012 Share Posted October 12, 2012 I'm experimenting with this in my Tron scene, specifically the light cycle. I like the way it's looking, but I'm noticing that the reflective surface is picking up some things, and then dropping others as the Samples and/or refl intensity are changed. I've got the Grid floor, which is made of two thin box, very large in size, but the height is very short. In between I've the rectangualr shapes, also very thin. The outer pieces have hte shader set up for glass, reflection and refraction turned on, and the inner shapes have the Glow shader on them. Looks good so far. When I put the bike on this, the bike is reflected in the floor OK. But the glowing rectangular shapes don't show up on the bikes surfaces, depending on the above mentioned settings on the shader. Setting the Sampels to anything other than 2 seems to make part of it go away. Am I missing something? I'll try and post images to illustrate this later. Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 12, 2012 Share Posted October 12, 2012 (edited) Can you post test scene/images to understand what happened? Edited October 12, 2012 by notawhale Quote Link to comment Share on other sites More sharing options...
jim c Posted October 13, 2012 Share Posted October 13, 2012 OK, part of the problem I solved - I made the glass shader partial opaque. The current problem is noise, there's a ton of reflective surfaces. Any ideas for how to address this? Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 13, 2012 Share Posted October 13, 2012 I think this is low samples and big angle on reflection. Quote Link to comment Share on other sites More sharing options...
bergj Posted October 13, 2012 Share Posted October 13, 2012 (edited) Nice work. Edited March 28, 2013 by bergj Quote Link to comment Share on other sites More sharing options...
jim c Posted October 13, 2012 Share Posted October 13, 2012 Check again, you have more options than what comes in the default Mantra Surface Shader. The Ubershader has blinn, phong, anisotropic, glossy, and Vex specular. Quote Link to comment Share on other sites More sharing options...
bergj Posted October 14, 2012 Share Posted October 14, 2012 (edited) Good call. Edited March 28, 2013 by bergj Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 14, 2012 Share Posted October 14, 2012 This shader in work. Now It have all basic function for production. And it isn't last release. Quote Link to comment Share on other sites More sharing options...
jim c Posted October 14, 2012 Share Posted October 14, 2012 (edited) Some more testing. The pic on the left shows reflection sampling rates set to 8, and the micro poly renderer set to have 4 sample. The pic on the right shows reflectation samples at 16-32 (depending on the material), and micro poly renderer set to have 16 samples. Lighting is done with 3 point lights. Is there anything I've missed here? It still seems kind of noisy. Edited October 14, 2012 by jim c Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 14, 2012 Share Posted October 14, 2012 This image is with constant box and reflection grid shader with 2, 16, 128 samples on 20 angle. If more samples, then lower noise in reflection. You wrote about change sample on refraction, maybe you change not this parameter? Quote Link to comment Share on other sites More sharing options...
symek Posted October 14, 2012 Share Posted October 14, 2012 Great work guys! Maybe it's time to put it on github or something? Quote Link to comment Share on other sites More sharing options...
jim c Posted October 15, 2012 Share Posted October 15, 2012 I'm trying to use the shader in a digital asset. But when I save the asset I get the following dialog - complaining about bits in the shader. In the asset, which is an object type, I have a SHOP node with my shaders in there, so the asset is completely self contained and ready to go. If I save anyways, it seems to work, but I'm curious as to what this means, is there a way to prevent this from coming up? Quote Link to comment Share on other sites More sharing options...
jim c Posted October 15, 2012 Share Posted October 15, 2012 As far as the noise, I didn't realize how high it needed to be set. Thanks for point that out. For me, 64 samples seems to do the trick, but it does make a big hit on the render time. Still, it's faster than PBR for this kind of scene. Quote Link to comment Share on other sites More sharing options...
notawhale Posted October 15, 2012 Share Posted October 15, 2012 (edited) I'm trying to use the shader in a digital asset. But when I save the asset I get the following dialog - complaining about bits in the shader. In the asset, which is an object type, I have a SHOP node with my shaders in there, so the asset is completely self contained and ready to go. If I save anyways, it seems to work, but I'm curious as to what this means, is there a way to prevent this from coming up? Don't worry about it. Houdini think symbol "*" and "space:world" is absolute link Edited October 15, 2012 by notawhale Quote Link to comment Share on other sites More sharing options...
jim c Posted October 15, 2012 Share Posted October 15, 2012 Another question - how would one go about modifying the asset to support the opengl viewport? For basic stuff like diffuse color, spec, etc? Is this possible with a shader like this? Quote Link to comment Share on other sites More sharing options...
