cloudfx Posted February 21, 2012 Share Posted February 21, 2012 Hi I am trying to light a object and looking for a way to select some object that I dont want them to be lighten up. Where do I find this command in light objects? Quote Link to comment Share on other sites More sharing options...
anim Posted February 22, 2012 Share Posted February 22, 2012 there is Light Mask parameter on objects so you can just put: * ^light1 to exclude light named light1 from illuminating that object there is also Shadow Mask on lights to exclude some objects from shadow casting you should be able to use bundles for these patterns have also look at Categories, they can be pretty useful for this as well Quote Link to comment Share on other sites More sharing options...
edward Posted February 22, 2012 Share Posted February 22, 2012 There's also the Light Linker pane. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted February 28, 2012 Author Share Posted February 28, 2012 there is Light Mask parameter on objects so you can just put: * ^light1 to exclude light named light1 from illuminating that object there is also Shadow Mask on lights to exclude some objects from shadow casting you should be able to use bundles for these patterns have also look at Categories, they can be pretty useful for this as well So if I dont want to get shadow from some objects(for example, woman_21,woman_22,woman_44 and man_86), I go shadow tab's shadow mask and do * ^woman* man_86 correct? Quote Link to comment Share on other sites More sharing options...
anim Posted February 28, 2012 Share Posted February 28, 2012 almost, however you need to specify ^ in front of every pattern you want to exclude, so it would be * ^woman* ^man_86 Quote Link to comment Share on other sites More sharing options...
