Is there a way to use a branch based on a condition?
magneto
I thought I could do this with a switch SOP but I need the connections going the other way around.
Basically I have foreach SOP that assigns an integer index to each primitive, and then I want to use this primitive to choose which color sop to use after that based on the index I created, but not sure how to do it.
So here is how it looks inside the foreach SOP:
Can I make it so that the integer chooses which color SOP comes after?
I could use stamping but I want to change the point colors.
Edited by magneto
Thanks Eetu, exactly what I wanted. I was somehow stuck in thinking I needed to do it the other way around, now I know :)
I made these images to show nord3d what I needed so I might as well post it to make it more clear:
This is how I needed to do it before:
whereas I wanted something like this which is a mockup, where the switch node decides which node comes after itself based on the index.
Of course Eetu's example does it perfectly.
Edited by magneto
