Best way to offset the randomization of values
When generating random values for different parameters using the rand expression, I see people multiplying the result with a value, or adding a value to the result, etc.
Which way is the most preferred way that gives the most chaotic results?
Is it enough to just do something like?
x = rand($PT)
y = rand($PT) + 1
z = rand($PT) + 2
I feel this will not provide as much difference for instance.
What are the best practices?
I am sure Houdini experts would have their consistent methods they always use regardless.
Magneto,
what SYmek suggested is right. You have to remember that random doesn't mean a casual number, but if you give the same seed to the function, you'll obtain the same result:
rand(5) = rand(5)
Now my formulas normally use big numbers for the seed, float numbers as SYmek says, and I use a little trick, let's say, to remember those numbers, in order to change always seeds:
My formulas are something like this:
x = rand($PT*159.357+741.23)
y = rand($PT*951.753+486.624)
z = rand($PT*426.684+123.654)
If you try to digit the above numbers on your numpad, you'll see soon they are numbers taken following diagonals (951.753, 159.357), "L" shapes (741.23), "Diamond" shapes (426.684), "dumb" shape (123.456 :D), etc.
It's like a "finger ballet", in this way I (should ;)) know to not use that kind of shape for next combinations or, if I'm in trouble, I simply copy/paste the previous formulas in different order, for example using the previous one, it will be:
x = rand($PT*741.23+159.357)
y = rand($PT*486.624+951.753)
z = rand($PT*123.654+426.684)
And don't forget that rand() gives you always values ranging in [0..1], so I quite often use it with fit01() function to control it better according to my needs.
Cheers.
Thanks for the input guys. This is all interesting.
@thinkingmonkey, when you stared talking about diamond shapes, I thought you were trolling :)
What about using prime numbers though? From what I know that's a good way to offset randomization in general programming. Something like:
rand($PT * 13)
rand($PT * 17)
rand($PT * 19)
But I didn't realize the non-integer advantage for the rand expression.
