Ripple solver interaction
Mzigaib
I got how I can make the ripple bounces to a area with zero wavespeed but how can I animate the initial ripple state throught time?
If I do that it just takes in consideration the first frame and I need my values to change over time, it seems I need to update the rest or the geometry data of the ripple object data inside DOPS anyone knows how could I do that?
Edited by Mzigaib
I can think of quite a few ways to do this with expressions, but without a more clear idea of your end goal I can't really formulate the right method.
You could try playing with the chops for the points. If you use the integration node (can't remember the name right now) you would be getting the position function for a given velocity curve, the slope node would give you a curve that represents the acceleration function.
You could try a damping function on the point node, but again, to make it right I would need to see an example of what you are trying to do.
  • Downvote 1
  • 3 weeks later...
Hi, sorry the delay.
I got some interaction but I would like to see the bounces on my virtual boat more apparent, any ideas are welcome.
testing_pointclouds_db_03.hipnc
Thanks.
Edited by Mzigaib
can you add a wavespeed attribute to your boat object (set to 0) and setting up an attribute transfer to the water plane. When you run the ripple solver it should inherit the attribute keeping the wavespeed at 0 where the boat is, allowing ripples to reflect off.
Edited by mjflicker
I think you can use multisolver & sopsolver to update attribute.
I tested with conservation before and it worked but I don't have the scene now.
Cheers
Thanks for the feedback.
If you take a look on my file you are going to see that I used multisolver and sop solver to update the wavespeed attribute and it works, you can see that the area where the attribute is updating makes the waves not just going throught the area, it makes the waves kind of reacting to it the only problem is that the effect is not that visible you dont have like real boucing back waves like the ones on the edges.
Edited by Mzigaib
Thanks for the file.
Yeah your file is almost same what I did.
Same thing what I said on my reply though, using conservation attribute instead gives me a little bit better bounce.
But not quite.
Sorry for not much help....
  • 1 year later...
Hi everyone,
I jump on this topic because I actually have the opposite problem. What do you would be the best way to generate a ripple effect from the edges of the object outward. And the object intersecting the flat surface is not actually travelling, but instead moving up and down.., sort transfering vibration to the surface.
Thanks for any suggestion
