upres h12
Hello world
I have a custom pyro setup.I have bgeo'ed lowres.I have problem with upres
The upres is playing in the upres dop node.however I dop i/o doesnt seem to extract.I have also tried using object merge ../../:upresdop/pyro.
but i dont see anything in the view port.
any pointers on this?
I wouldn´t go that far luke (even if you were my father :D)
It´s true that upressing ain´t a need anymore, but it´s also true that raising the pyro container divisions almost always changes the fluid behaviour in some way (sometimes dramatically).
So IMHO upressing can still be a valid method when you are quite happy with the motion and behaviour of your lowres testing.
Edited by Netvudu
  • Downvote 1
mhhhh trie to take the velocity field of the lowers simulation and drive some particles with it... and then drive a totally new pyro simulations with those particles... u should get the same motion and the same look but just in a better quality....
dont change any settings or what so ever on the new pyro sim... just up res it and bring the particles as vector field.
That could solve ur problems, maybe;P
