using sop velocity attribuet to DOP force
cloudfx
I am trying to bring my velocity that I made in SOP with curve to DOP as force to use it for Cloth and RBD object( not fluid/pyro)
Would there be any examples?
I tried to use vop force in dop but not quite working and help does not have examples..
you can use Field Force DOP
very powerful node, it can take many different types of sources for your force (vector attributes from points, vector fields, scalar fields)
look at the help for explanation and few examples
here is hip file,
I am using the field force but not working.
forceTest.tar.gzFetching info...
don't be afraid to set Scale Force to high values
just for seeing if it's working
try 500000
and uncheck Use max distance because you are now limiting it to 1 so objects further than 1 from the curve don't receive any force
try 500000
Yes, I was too afraid!.
now its working :)
