HDK and XCode4
Has anybody got a working project or template setup for Xcode4 that works with the HDK?
I am aware of hcustom but I'd like to get it all working inside xcode. I tried adding the .framework in the build phase and adding header and library paths but no luck.
  • 1 month later...
Was fiddling with XCode today and have it working quite well.
Here is a XCode Project Template that has a shell script as a build target.
It includes a perl build script, that :
  1. sets up houdini environmental variables.
  • checks directory for all .C files that are operators
  • checks if the dso file needs (re)compile and runs hcustom to compiles if source file is newer
  • if a .png or .svg or .icon file exist with the name same operators internal name it will copy it to the correct ...config/Icons directory
Place this in :
/Developer/Library/Xcode/Project\ Templates/Other/HDK
HDK.zip
Another idea might be using the cmake configuration file from this the RmanPtcSop project: http://danbethell.github.com/rmanptcsop/
From an email 2 yrs ago,
It certainly took a while to
dissect the makefiles and dig around in headers for the magic mac
compilation flags. It's all wrapped up as the FindHoudini.cmake module
in config/cmake so hopefully will save others some time/pain if they
fancy diving into the HDK
Maybe the OSX cmake can generate the XCode 4 project for you.
  • 3 weeks later...
[/size][/font]
yes yes "cmake . -G Xcode" does
it is need to link $HDK_LIBRARY_DIRS $HDK_STANDALONE_LIBRARY_DIRS
and change compiler type to LLVM GCC 4.2 instead Apple LLVM compiler 3.1
Lanuch Xcode from console after source houdini_setup_bash
