FBX Imported Object gets trasnparent with reflections on?
Hi there.
When I import the object into my scene through an FBX everything looks ok, until I activate reflections on the Mantra Surface material. When I do so, the object seems to become a bit transparent.
I´ve imported other FBX object without such behaviour...anybody knows what´s going on here?
I can´t upload the scene because the object weights around 40 megs.
  • 7 years later...
Old thread, but I recently faced the same problem. To solve it if it is like my case:
Check in the Geometry Spreadsheet if the vertices have Cd and Alpha.
If so, use
  • attribute delete node to delete the Alpha from vertex attributes.
  • attribute expression node to set the vertex Cd attribute as white.
Edited by Ippokratis
